HUTSUTAo
High-Rev Hero
Mercedes 4-CYLINDER Petrol ENGINE M 254 COMES IN 2020 -
MARKUS JORDAN
NOVEMBER 17, 2019
Mercedes-Benz will probably introduce the new 4-cylinder M 254 petrol engine towards the end of 2020, completing the rollout of the new Mercedes-Benz engine family. The M 254 is the successor of the M 274 and part of the new modular engine generation.
M 254 AS THE LAST MEMBER OF THE CURRENT ENGINE GENERATION
The M 254 is expected to have a displacement of two liters, as it will have an identical cylinder displacement of around 500 cc as part of the Mercedes-Benz modular engine generation.
A clear advantage of the M 254 series is that the modular engine construction kit from Mercedes-Benz with uniform cylinder spacings makes it possible to produce the engines more cost-effectively on a common production line.
CERTIFICATION TO EURO 7 EXPECTED
This means that the successor generation of the M 274 has the same capacity as a four-cylinder in-line and will later be used both in transverse and longitudinal installation at Mercedes-Benz. When using the engine is parallel to expect that the new four-cylinder is already certified to Euro 7.
Reihen 4-Zylinder Benzinmotor M 254 von Mercedes-Benz kommt 2020 - Mercedes-Benz Passion Blog / Mercedes Benz, smart, Maybach, AMG
MARKUS JORDAN
NOVEMBER 17, 2019
