C-Class W205 Problems, Malfunction or any other troubles with your C-class w205 2014 2015 ?
The Mercedes-Benz W205 is the fourth generation of the Mercedes-Benz C-Class which was produced by Daimler AG between 2014 and 2021. The W205 C-Class was preceded by the W204 C-Class and superseded by the W206 C-Class. The fourth-generation C-Class was available in sedan (W205), station wagon/estate (S205), coupe (C205), cabriolet (A205) and long-wheelbase sedan (V205) body styles.
benzw205
Das Erste Gear
Hello,
How is your C-class ?
How long do you have it and how much did you drive ?
Still no problem ?
Or what do you have to complain about ?
Thank you for your insight.
I have my C300 since late September. I've had it in for two recalls so far. The steering column had to be inspected for a defect, and my front 18" Continental tires had to be replaced under a recall. I was unhappy with the poor fit of my fuel filler door, and that was replaced by the dealer. That's been it.
Thank you.
What was wrong with the Continental tires ? Never heard about tires recall in my life ???
Thank you.
Recall 2014100004 OCT14 – ContinentalTire the Americas, LLC (CTA) is conducting a recall on approximately 5,993 Continental PROCONTACT GX SSR MOE 225/45R 18 95H XL tires, that may be mounted on the front wheels (only) of approximately 5,500 MY 15 C-Class vehicles (MBUSI Sedan only). These tires may have been deformed during the curing process. It is possible that affected tires may exhibit vibration and/or noise, and in rare circumstances the directional stability of the vehicle may be affected. Dealer will replace tires. Owners should receive a letter, or have dealer check Vehicle Master Inquiry to see if VIN is included.
benzw205,
JLBM,
