Mitsubishi [SCI]: Mitsubishi Lancer Evo X Review
Mitsubishi Motors Corporation is a Japanese multinational automobile manufacturer headquartered in Minato, Tokyo, Japan. Founded in 1970, Mitsubishi's automotive origins date back to 1917, when the Mitsubishi Shipbuilding Co., Ltd., introduced the Mitsubishi Model A, Japan's first series-production automobile.
bmer
Tire Trailblazer
Faster, Less Furious
We travel to Japan to get our first taste of Mitsubishi's all-new Lancer Evolution X.
It’s Godzilla-breath hot in Japan, sticky and steamy and scorching. I’m supposed to be lapping the new Evo X around Mitsubishi’s Tokachi Proving Grounds, but I’m spent: In this heat, I can’t guzzle these strange Asian soft drinks—Pocari Sweat, or Calpis, or Qoo, or Fire Milk Taste—fast enough to stay hydrated. Nor, from the look of the cans, do I want to.
No, forget that last hour of track time: I’m parking myself under this tree for a nap. But I can’t sleep. Not with the 99.97 percent humidity blurring the line between breathing and drowning. Not in this primeval Japanese forest filled with cicadas the size of Dalmatians. And not with this affable engineer chatting me up in the Evo nuts’ lingua franca, Middle High Mystery Acronym.
“So! The S-AWC really helps helical LSD and S-ABS integrate with ADC and AYC, don’t you think?!”
I agree, but just out of live-and-let-live principle. For all I know, ADC is some kind of lower-intestine disease.
“Just so! Because with MIVEC, even EBD and RISE aren’t enough sometimes! Hah hah!”
I’m the first to admit Mitsubishi has cooked up a heck of a car. It’s as fast as a Mustang V8 and pulls near-as-heck one full g around the skidpad. It gives no speed away to the old Evo IX yet is infinitely calmer and smoother. Stylistically, where the Evo IX looked like a New England saltbox with lots of additions that weren’t built to code, this one is pure retro-anime Ultraman. (Mitsubishi says the distinctive front end is “inspired by jet-fighter intakes,” neglecting to add “from the Korean War.”) In short, the all-new Evo X upholds the brand’s driving credentials, recruits new buyers through added civility and placates the existing Evo crowd with its groin-kneeing, furious-guppy design cues. Still, this car also marks the point at which Mitsubishi’s acronym fetish is officially out of control.
During an earlier track session, I noticed a small console button marked “AFC.” Automatic Fish Counter? Active Flea Control? Anorexic Floozy Collector? No idea. So I pushed it. No difference. At the end of that lap, I collared a Tokachi Proving Grounds engineer. He pushed it. No difference. He consulted an engineer flown in from Tokyo. “I dunno,” the second guy said. “What happens when you push it?” Eventually, three professional journalists and four Mitsubishi engineers came to the general conclusion that AFC was a system whose sole purpose was activating the AFC warning light.
Don’t get me wrong; I love what these three-letter systems accomplish. This tenth iteration takes the Evo brand over a critical line—the line between feeling fast and effective due to breathtaking technical wizardry and just feeling fast and effective. Given this stellar achievement, I’d just as soon not be reminded that when I crank in a bushel of ham-fisted lock, the Evo X follows a laser-line path to the apex because S-AWC is telling ACD to send just enough torque back to AYC to counteract helical LSD while ASC adds in some more S-ABS. Now that Mitsubishi has finally made it invisible, I’d rather just think it was me.
The Evo X is a bigger, heavier, quieter car than the IX—more substantial and much more grown-up dynamically, if probably not so aesthetically. This all comes down to the growth of the base-model Lancer, which gains an inch or two in every dimension and over 200 pounds. Naturally, the same thus holds true for the Evo, despite the model-specific use of aluminum for the hood, front fenders, bumper beams, roof and suspension bits. The result is a solid-feeling machine with great noise/vibration/harshness isolation and top-notch rigidity (even the base Lancer is stiffer than last year’s Evo IX; the Evo X gets additional bracing from there), but less of the old Evo’s boy-racer drama. Additionally, fewer interior pieces now betray the car’s crap-can origins: The door panels still look like a two-buck harmonica case, but the gauges and switchgear could almost have come from a car this expensive.
Also gone is the long-serving iron-block 4G63-TC, an engine now old enough to vote. The Evo X carries an all-new, all-alloy, model-specific inline-4 called 4B11-TC; rather than a balance shaft, this one gets manners from a perfectly square bore/stroke ratio, tuned hydraulic mounts and the Lancer’s upgraded chassis. Variable valve timing is fit to both cams, not just the intake, and drive is by chain, not belt. The lobes now act directly on the valves rather than working their mojo through wee little rockers, and the exhaust orientation has been switched—the header sits on the firewall side, allowing for a straighter, less flexible front-chassis crossmember. On a related subject, smoother exhaust and a retooled compressor help combat turbo lag, a promise one drive quickly verifies. The upshot is a Mitsu-estimated 295 horsepower at 6,500 rpm and 300 lb-ft of torque at 4,400, versus the Evo IX MR’s 286/289. While both engines displace two liters, the new one is smaller externally and 27-plus pounds lighter.
The last Evo’s suspension layout is carried over (inverted struts with aluminum control arms up front; upper wishbones, lower control arms and trailing arms at the rear) using all-new parts and geometry. More importantly, everything now pushes back on a ridiculously stiff platform. Compared to the already rigid Evo IX, Lancer development boss Hiroshi Fujii claims the new model is 39 percent more rigid in torsion and has 64 percent less flex. Stronger steel, straighter rails and deeper gusset areas strengthen all Lancers; on Evos, the aforementioned flat front crossmember gets additional beef in the leading edge, rear attachment points and through a separate forward crossbar. At the back of the Evo, a new V-brace behind the seats complements sturdier suspension-mount areas and a stiffer, straighter trunk floor. The benefits of the new structure are immediately apparent on Tokachi’s “Mountain Road Course,” where ripples and bumps that unsettle the Evo IX—mandating immediate steering corrections or the death of a lot of small shrubbery—go almost unnoticed in the stiffer, better mediated, more softly sprung Evo X.
Previous Evos have followed a gradualist model, with each getting a little bit further from its original Mitsubishii evolipthicus ancestor. That would be the loud, random, hilarious ’92 Evo RS, a car that felt like nothing so much as a 244-horsepower Pachinko machine. The Evo X, on the other hand, argues for catastrophism: It’s all about big, creature-altering changes taking place in just one generation. Gone are the earlier Evos’ funny noises, scrabbling tires, crack-the-whip traction and fantasies about CGI tailpipe flames. In their place you get well-controlled grip on rough pavement, a good sense of front/rear balance, accurate steering and fast and predictable throttle response. It’s a little like going to sleep with Courtney Love and waking up next to Angela Lansbury; there’s no question you’re better off, but you can’t help feeling a tiny bit wistful.
If you do manage to get into trouble, the X also boasts excellent brakes, once again taking the form of huge Brembos. The rotors are regular one-piece units on the Evo GSR and lighter (by almost three pounds) two-piecers on the Evo MR. Wrapped around these are two different 8.5 x 18-inch wheels, a 22-pound cast-alloy Enkei for GSRs and a 20-pound forged BBS on MRs. The costlier MR also gets standard HID headlights, Bilstein shocks, Eibach springs, a big wing and in-cabin Bluetooth—which, save for the suspension bits, are optional on the GSR.
If you assume this means the MR remains Mitsu’s hot rod, whoa-up there, Vin Diesel. You can keep your forged alloys and dual-segment rotors: The real choice in ’08 is between the 5-speed manual GSR model and the 6-speed, dual-clutch, self-shifting semi-auto MR. Sure, the blather surrounding the new Getrag semi-auto promises the speed and efficiency of a manual, the convenience of an automatic, budding peace in the Middle East and a spectacular recipe for brownies. But sorry lads, I’ve heard it all before, and from the His & Hers Hurst of the ’60s to BMW’s Notorious SMG, it just isn’t so. The Getrag is a fine gearbox, but it still can’t read minds and it still trades convenience for driver involvement.
Called Twin Clutch Sportronic Shift Transmission (TC-SST to its friends), the Getrag forks up fabulous changes in most situations. But the issue with such transmissions is never the shifts themselves, it’s the electronic decisions that go into making them. Being a dual-clutch design, the Getrag constantly pre-selects what it thinks the next gear will be. That helps a lot when conditions are basically normal, but if you want to do something odd—back off the gas and then ask for an upshift, say—it doesn’t quite know what to do. Similarly, even in S-Sport, the most aggressive of TC-SST’s three modes, it refuses to pull as screaming a downshift as you would and won’t hold a gear when you back off to let someone pass.
Undoubtedly, TC-SST makes sense for commuters; it just isn’t very interesting for car nuts. The GSR’s 5-speed manual makes this car much more enjoyable, particularly now that the previous Evo’s rubbery bag-o’-gears shifter is gone. There’s still no mistaking the new linkage for anything other than cables, but at least it’s now snicky and accurate. And as for the TC’s much-touted magnesium shift paddles, well, I put those right between carbon-fiber tongue depressors and titanium back scratchers on the sensible-use-of-materials scale. The fact is, car companies inevitably pitch semi-autos as “sporty” precisely because that’s what they aren’t; no matter what the selector is made of or how many F1 cars use them, street-machine paddle-shifters don’t exist to enhance driving pleasure. They exist to sell cars to the ever-increasing millions who won’t (or can’t) deal with a clutch.
This manual/paddle division cuts right to the heart of the Evo X story: Can a more civilized, less hyperactive Evo really maintain the brand’s much-cherished outlaw image? Put another way, is a smoother, better, more civilized, less raucous, self-shiftable Evolution really so smart an idea?
Part of the answer comes down to speed. Even if the power-to-weight ratio falls off a bit—which, depending on finalized numbers, it could—the improvement in power delivery and traction means this new model will prove faster on real-world roads. It’s not going to feel faster, since a lot of the last Evo’s banging and bumping and whooshing and clawing won’t be there, and some spiky-haired malcontents will miss all that raw personality. But for every potential Evoist who’s legitimately fast and furious, ten more are just quick and a little disgruntled. A car that’s rude on the outside and pleasant on the inside is a much more salable item than something vice-versa, and that’s the theme of this new Evolution. I’m not down for a self-shifting MR, of course, but as somebody old enough to no longer have hair left to spike, the civilized Evo X GSR has an (insert mystery acronym here)-load of appeal.
bmer,
-=SIDHU=-,
